yep, Id also say toe-in.
Theres 2 ways of checking it....
Does the front of your car lift up (rather than the rear squatting down) when taking off or accelerating? If yes, its toe in.
When you go thru a corner, does your car want to straighten up, or keep turning? Drive thru a corner and let go of the steering wheel - the wheel should go to "straight ahead" instantly if you have toe out (which i reccommend).
I think you might have bigger problems though Will. When i was following you the other night, your car was "crabbing". Your back wheels run slightly closer to the gutter than your front wheels. If i am right, you are pointing your steering wheel slightly to the left to keep the car straight.....
I'd suggest getting the rear trailing arms inspected for wear also. You never know what you'll find
