It is currently Sat Jul 19, 2025 4:00 pm
 Post subject: Is the Fan Right
PostPosted: Mon Oct 25, 2004 8:45 pm
is this fan on the correct way PLEASE reply ASAP
poeee edit/ pixed pic link
PostPosted: Mon Oct 25, 2004 8:48 pm
Looks like it's been copped?
PostPosted: Mon Oct 25, 2004 8:55 pm
...to answer your question, it should blow into the guard.
PostPosted: Mon Oct 25, 2004 9:01 pm
it looks right. But your making me think now. you will know it's right where the metal insert on the fan bolt holes are to the outside. ie next to the radiator, not the engine.
Aaron
PostPosted: Mon Oct 25, 2004 9:26 pm
it just looks different to my other one
too radiator off and is getting cleaned at the moment soo before that goes back on just want to make sure fan is on right way
As i do not want to take it out again f&*^^ng bottom rad bolts and cowling screws :x :x :x :x :x
 Post subject: Re: Is the Fan Right
PostPosted: Mon Oct 25, 2004 11:23 pm
You are talking about the plastic fan....with the flat section toward's the radiator...You will notice on it it does say "Engine side"
Re fit radiator.... :lol: and hoses. :?:
Why is it so black and White...Black to the back and White to the front.... :idea:
PostPosted: Tue Oct 26, 2004 8:38 am
I thought the fan had to pull air into the engine bay, from under the guard?!?
PostPosted: Tue Oct 26, 2004 8:46 am
Yer it does.......If you have the Fan around the otherway it doen't :x
PostPosted: Tue Oct 26, 2004 8:51 am
:? ....but Mr. Pocock was sayin the opposite.....
PostPosted: Tue Oct 26, 2004 9:13 am
The fan pushes air coming in through the grille out under the guard. Or it should if fitted correctly...
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Oct 26, 2004 9:49 am
so your saying that it does look right?
not sure why it came up looking black and light maybe sunlight
PostPosted: Tue Oct 26, 2004 10:19 am
Looks right to me. 8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Oct 26, 2004 10:20 am
guys guys guys...
the fan will push air the correct direction regardless of the way you put it on..
you cannot change this..
but because the fan is an aerofoil design (each blade looks like a little areoplane wing) its more efficient (like alot more) when put on in the right direction
the airflow in a mini is different to most engines where the radiator is the last thing the air sees before leaving the engine bay.. air comes in the grill then through the fan and out under the guard (so the fan is actually blowing away from the engine)
make sure the little metal inserts in the bolt holes in the fan have the built in washer facing away from the engine. (ie the bolts have metal to face onto not plastic)
if your unsure what i mean look at the fan. one side the holes have a small metal ring showing.. the other side the metal ring is alot bigger.. the big side is away from the engine, the small side is towards the engine
Expert in training
PostPosted: Tue Oct 26, 2004 10:21 am
i'm pretty sure yours is right by the way judging by the fins
Expert in training
Users browsing this forum: Bing [Bot] and 76 guests
