It is currently Sat Jul 19, 2025 10:06 am
 Post subject: 850 exhaust bracket
PostPosted: Sat Oct 30, 2004 5:48 pm
I was just trying to fit the new exhaust to the 850, an i am having trouble with the bracket that bolts to the gearbox. :evil: The old exhaust was from a remote change box, so i can't put it back the same as the old, before you state the obvious. This is one of the reasons for a new exhaust, the other being the huge rust hole in the muffler.
All you people with an 850 can you tell me if the engine pipe bracket mounts underneath the gearbox lug, on top of the lug, or is there another bracket that allows it to sit beside the lug? Any way i try it something at one end or other does not line up.
photos would be GREAT
thanks
mcihael
PostPosted: Sat Oct 30, 2004 10:01 pm
Hey it's on;y been 38 years since I had one, but..
The proper 850 pipe has a bracket welded to it that goes UNDER the lug on the gearbox.
One of the tricks was getting it tight in the top joint, and getting the bracket close to the lug. Washers may be needed.... :wink:
PostPosted: Sat Oct 30, 2004 11:42 pm
Thanks dr
i have engine pipe with bracket welded on, but when i tried it as you suggested i could not get the bracket to go under the lug and make it mate at the manifold.
This is the distance between the manifold and the bottom of the lug
[--------------] is the distance from the bracket on the pipe to the flare......
i'll have to tighten it at the top, and kind of lever the bracket under the lug i guess. Not sure how the washers would help in this case. if the diagram was the reverse it would help
michael
PostPosted: Sun Oct 31, 2004 5:29 am
I know what you mean.
You could cut the pipe off below the flange, weld a repair section on there carefully, to get the length right. If they still make them.... :roll:
Or go buy a new 850 pipe...
or cut the bracket off the old one and move it a bit, then weld on again (messy...)
PostPosted: Sun Oct 31, 2004 11:17 am
this IS a brand new pipe :twisted:
