I am currently running a Lucas 29D dizzy in my Mini K. I have a standard 1089 engine with an unleaded head, twin 1 1/4 SUs and LCB.
I have tuned it to 15 BTDC at 1000 rpm (with the vacuum advance unplugged) using a timing light and whilst it runs well most of the time it runs rough over 3000 rpm when on the road (in all gears).
I replaced the points and regapped them at 0.35mm and put in new RN12YC plugs gapped at 0.6m but the problem still occurs. On inspection of the dizzy I noticed that the Vacuum advance is slightly lose but can not be tightened any more could this be the cause of the problem
If my vacuum advance is faulty what are the signs to look for
Do I really need a vacuum advance or can I remove it completely
Thanks Martin
