It is currently Sat Jul 19, 2025 8:23 pm
PostPosted: Mon Feb 07, 2005 7:00 pm
well i was driving the other day and my seedo stopped working it said i was going 160km, i didnt think my car could even go that fast, i took the wire off the back it all looked ok and put it back on, the speed moves up and stays at the highest speed then gradually goes down??? has anyone had this problem :S
Also my petrol gauge dosnt work i think it is the floating device in the fuel tank does anyone know where i could get a new one from?
PostPosted: Mon Feb 07, 2005 9:37 pm
We have an ad in our club for a mob called Southwest Instruments in the Campbelltown area. I've spoken to them on the phone and they sound really helpful. Give them a call and see if they can help you out. I don't have the number on me but i'm sure they're in the phonebook. if not i'll get the number for you later.
Bob Slattery
PostPosted: Wed Feb 09, 2005 10:34 am
Speedo problem most likely broken spring or worn bearing inside speedo head. Professional fix required.
To check fuel gauge disconnect wire from sender in boot. With ignition on gauge should read empty. Connect wire to ground(body) and gauge should read full. If gauge reads full problem is sender in tank. If gauge still reads empty then problem could be gauge or instrument voltage regulator. Volt reg is mounted on back of speedo/instrument panel. Also could be broken or disconnected wire.
RonR
 Post subject: speedo and fuel gauge
PostPosted: Wed Feb 09, 2005 12:16 pm
Hi Daniel,
Saw your car down at the mechanic the other day while my nissan patrol was getting a service.Hope you were happy with him.
As for the fuel gauge it gets 12volts straight off volt regulator which is mounted behind speedo.get a test lamp and see if you have 12 volts at wire on sender unit.If there is 12 volts remove sender unit and check the resistive wire on the arm(ensure fuel tank is nearly empty before removing sender.)
as for speedo theres an instrument man (st george instuments) on th Grande parade at Sans Souci just near the shops at ramsgate rd .
Regards Felix :)
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Wed Feb 09, 2005 1:09 pm
mini_me wrote:
Hi Daniel,
The regulator drops the voltage to 10 volts - and keeps it smooth so that it doesn't fluctuate with the alternator
David L
PostPosted: Wed Feb 09, 2005 9:29 pm
oh boy
the kids only 16, not sure if he's an experienced grease monkeys as us all
i think you'll have to explain the testers etc
Inconspicuously Conspicuous
Users browsing this forum: No registered users and 69 guests
