It is currently Sat Jul 19, 2025 3:25 pm
PostPosted: Thu Feb 10, 2005 9:33 am
Why are the present systems different to the older systems? I think it was because the overflow bottle could be made more cheaply as it did not have to be pressurised. I would use the early type as the return valves in the radiator caps commonly fail.
Chris
Everything I like is either
PostPosted: Thu Feb 10, 2005 11:20 am
just make sure that wherever you mount it, that it is at least partially higher than the top tank of the radiator. air will always migrate to the highest point in the system, so if the tank is lower than the top of the radiator, you get an expansion tank full of water and a radiator with air in it.
PostPosted: Thu Feb 10, 2005 11:29 am
My daughters sillycar has the o/flow tank down on the subframe way below tha top tank
David L
PostPosted: Thu Feb 10, 2005 2:39 pm
Yeah cheaper and it also means that you can top up the coolant when the radiator is still hot.
Users browsing this forum: Bing [Bot] and 89 guests
