It is currently Sat Jul 19, 2025 10:16 pm
 Post subject: handbrake
PostPosted: Mon Feb 14, 2005 7:08 pm
just wondering why my handbrake doesnt work and never has it has no effect at all even when fully engaged. i have fitted new brake shoes and drums but this hasn't helped. is it just a matter of tensioning it somewhere or something totally different?
can someone please tell me how i can make it work????
thanks alot
PostPosted: Mon Feb 14, 2005 7:15 pm
so your rear drums are adjusted right?? if so then there is an adjustment on the actual hand brake lever,, if there all done up then id say the cable has stretched over time or it has come loose form the mounting points on the rear of the drums.
1974 Moke - 998cc
PostPosted: Mon Feb 14, 2005 7:47 pm
thanks 13sec, ill have to check out the cable see if its got problems. havent had a real good look at the mounting points as well.
PostPosted: Mon Feb 14, 2005 8:16 pm
Also check the cable quadrants on the trailing arms, if frozen solid the handbrake won't work. :cry:
PostPosted: Mon Feb 14, 2005 9:03 pm
Back to my favourite hobby of hijacking posts!! :P
I've done almost everything I an think of to get m handbrake working better for motorkhanas. It has brand new oversize shoes, machined drums to suit. new cables. I'm 90% sure it has been adjusted properly, but I will check that again. Any other ideas people?? It will hold on hill - hell it'd almost hold vertically!! Just can't get it to lock too well in the motorkhanas - and all the ones I've been in so far have been on grass! Wait till I get to the tarmac 'khanas!! :shock:
Bob Slattery
PostPosted: Mon Feb 14, 2005 10:46 pm
mr bob i reckon its the timing of the handbraking.
the faster you do it, the quicker the wheels will lock
if you do it slowly, handbrake turns wont happen, the car will just slow down
Inconspicuously Conspicuous
PostPosted: Tue Feb 15, 2005 7:47 am
how hard is it to pull on, how far up does it come. I have the same trouble with my van, it's all set up properly but I think I've got it adjusted too close to the floor, I can't get any force when I pull it on. The shoes I have are a hard compound, great fo teh track cos they're less inclined to lock, I've got a mate who ordered a special soft, sticky compound and they work incredibly well in the 'khanas.
Best mod someone ever told me was to push the button in, drill a hole through the lever and button, and put a bit of coathanger through it and bend it over, and some tape over it - voila, flyoff handbrake
hydraulic handbrake is the next step..... I've been planning one for the van, but not doing it anymore cos handbrake turns with 4wd doesn't work :roll:
PostPosted: Tue Feb 15, 2005 10:39 am
I already have a fly-off handbrake. mini is even simpler. it is a hole drilled through the base of the lever, then when khana'ing (nice made up word there) i put a split pin through which disengages the rat crap. (i love that joke). :lol:
and about the speed, to give you an indication, my first khana i actually ripped the whole lot off the floor by reefing it on too hard!!
I think one of my problems is flex in the floor of the car. When time/money permits i will get someone to weld a piece of angle in to mount the whole lot on and make it a little more solid.
Bob Slattery
Users browsing this forum: 68+86auto, Aussie Brian and 92 guests
