It is currently Sat Jul 19, 2025 10:18 pm
PostPosted: Wed Feb 16, 2005 8:14 pm
Hey everyone,
My father and I have been trying to fix our poor lil' clubbie and we have run out of ideas, the mini in question is playing up and we have done every thing but take the motor out and rebuild it (not to keen on that idea) the symptoms include; when started and taken onto the road and then accelerate the power dies and when up to speed it isn't constent we often have to keep accelerating and decelerating to keep it at a constent speed so we have replaced; the high tension leads, the rotor for the dizzy, the points for the dizzy, the condenser for the dizzy, the spark plugs, coil, tuned the carbie and fixed the timing. But it is still fouling up something cronic. If anyone can help with information it would be greatly needed.
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Wed Feb 16, 2005 8:17 pm
Try a completly different dizzy it sounds like the springs are shot and it is changing the advance curve hence timming.
Aaron
PostPosted: Wed Feb 16, 2005 8:20 pm
Thanks for that arron i'll check in the shed if I can get the dizzy off my van
does the dizzy from a 1970 mini van 1100cc fit in a 1971 mini clubman 1100cc
they should, shouldn't they?
Pat
PostPosted: Wed Feb 16, 2005 8:23 pm
I'm with Aaron....
Or, it could be some other leccy prob. I had an LJ Torrie years ago that did similar things. I replaced the motor entirely and it still did the same. I put it down to a wiring fault....never did fix it....just sold the car. :?
PostPosted: Wed Feb 16, 2005 8:28 pm
yep the dissy's will swap no worries, there probably the same unit.
Aaron
PostPosted: Wed Feb 16, 2005 8:33 pm
Yer
I'll check whether they look the same in the morning because it is to dark right now and cannot see a bloody thing
I just wanna fix it so I can go to this thing in bundy in a week
Pat
PS Dad will probly take the dizzy off tomorrow and ill take it apart or something like that and change them over or just use some of the parts off my dizzy on it
They should be interchangable shouldn't they?
PostPosted: Wed Feb 16, 2005 8:37 pm
yeah they are. I would be surprised if they arent identicle and there only a year apart in age. Of course they will probably different as they may have been swapped at somepoint in the last 30years.
aaron
PostPosted: Wed Feb 16, 2005 8:38 pm
Aaron
Users browsing this forum: 68+86auto, Aussie Brian and 91 guests
