nuclear_mini wrote:
gafmo, can u enlighten to un-enlightened about the differences between the heads.... the 940 is a 1275 head right? otherwse?
I think Gaf was talking about a 295 not a 925...
202 and 295 are both small bore heads, better than the common 12A1456 fitted to 850 and 998.
202 head can be modified (with a fair bit of work and $$$) to flow as well as/better than a 295 one- which is the gun head but getting scarce.
940 and 1316 are 1275 heads.
1316 is used on LS and 1275 Moke- basically it's a 940 head casting with air injection ports added to reduce emissions.
When you consider (12G)940 heads, there are various types:
Morris 1100S (9 stud) 1.312" inlet valves
Mk2 Cooper S (11 stud) 1.401" inlet valves
Other 940 heads below were not sold here, but some have been brought in since:
Metro 1.312" inlet valves
MG Metro 1.401" inlet valves
MG Metro turbo 1.312" inlet valves, sodium filled exhaust valves with bigger guides.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
