It is currently Sun Jul 20, 2025 2:17 pm
PostPosted: Sun Feb 27, 2005 6:21 pm
or u could buy a plastic race tank stick it in the middle of the boot and put to filler tube one from either side if u want the twin tank look. or just one if u are out for more capacity
PostPosted: Sun Feb 27, 2005 10:43 pm
Chris wrote:
I was looking at a left hand tank the other day and thought it wouldn't be that hard to make one if the need arose. The filler tube could be ratted from a RH tank. It might not end up spot on but I bet it would do the job and be a reasonable facsimile of the original. Or moulds could be made and then make a fibreglass one? Would beat paying the sometimes stupid money people sometimes ask for them.
I got my lefts and rights mixed up didn't I. :roll:
Chris
Everything I like is either
 Post subject: You did!
PostPosted: Mon Feb 28, 2005 9:52 pm
Just remember Cris...your left is your other right! :?
PostPosted: Tue Mar 01, 2005 8:56 am
If it is extra capacity you are after and not the look of twin tanks it is possible to enlarge your current tank (or a second hand LH tank). I can remember seeing a tank that had been split down the middle and an extra couple of inches added and then re-welded.
This seemed like a good idea to me at the time and I figured it probably would not cost too much to do.
Users browsing this forum: drmini in aust and 89 guests
