It is currently Sun Jul 20, 2025 9:20 pm
 Post subject: engine mount
PostPosted: Mon Mar 07, 2005 7:36 pm
the engine mount in my clubby is always falling off its the one next to the radiator. i tried putting a screw with a bolt at the end but it just falls off. What do i need to get to fix it, i have the rubber in the end of the mount but the metal piece on the inside is missing?
PostPosted: Mon Mar 07, 2005 7:57 pm
you will need to get yourself a new one $7 (for a roundy) from MG spares in Smithfield,
or about twice that around other places.
you will need the five bolts, three nuts and three washers with that
Inconspicuously Conspicuous
PostPosted: Mon Mar 07, 2005 7:58 pm
daniel or are you talking about the steady bar from fire wall to radiator
engine mount is down the bottom, radiator to subframe
PostPosted: Mon Mar 07, 2005 8:11 pm
yeah its the one from the fire wall to the radiator to keep it steady!
PostPosted: Mon Mar 07, 2005 8:29 pm
righto thats called an engine steady bar (i believe)
and its supposed to have four round rubbers (two on each end) with a metal sleeve on the inside (as you have stated!)
i just went to the local hardware store with the rubbers (about $2 each)
and they picked out a fat bolt and nut (with a washer)
so i wouldnt need the metal sleeve
i had to enlargen the holes in the brackets with a drill though
not sure if this is good enough
PostPosted: Mon Mar 07, 2005 10:33 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
dooke the metel bar is ther for a reason
i run nolathane some people recon they are to hard but i like em
makka
PostPosted: Mon Mar 07, 2005 10:40 pm
Are you have two Engine steadies on a Rod change...
I'd just do the rubber with two steaties..
But saying this Morris us's nolathane and so will Marcia
