It is currently Mon Jul 21, 2025 12:49 am
PostPosted: Mon Mar 14, 2005 8:53 am
Noticed yesterday that my ignition light is staying on after starting. Any ideas on what could be wrong?
Normally only comes on while starting or when the revs are really low after first starting. Give it a few revs and usually goes out. Not this time!
Looking at the wiring diagrams it "could" be related to the alternator or control box.
Ideas? Cheers.
67 S
PostPosted: Mon Mar 14, 2005 12:35 pm
is alternator or control box for sure. always had the same symtom when a generator let go
PostPosted: Mon Mar 14, 2005 5:36 pm
Altinator is on last legs..You will find the Battery will be dead shortly...
Get the Altinator services...$60 to $110 worth
PostPosted: Mon Mar 14, 2005 6:52 pm
check it's not just the wires loose on the back the alternator too
PostPosted: Mon Mar 14, 2005 6:57 pm
also check the connections on the started solonoid. i had this problem not long ago.
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Mon Mar 14, 2005 7:41 pm
Yep totaly agree...Rather than Jumping to Conclotions :idea:
