It is currently Mon Jul 21, 2025 7:58 am
 Post subject: Fuel sender?
PostPosted: Thu Mar 24, 2005 10:19 pm
ok a while ago i bought nice new shiny gauges for the mini. went back and got the senders for them later. all was good but i thought that the fuel sender looked a bit odd to go in a mini tank but the guy told me it was for a side mounting tank so i take it anyway...
about a week ago i got around to fitting it only to find it is very very wrong the arm comes out of the resistor unit thing from totally the wrong way so i take it back. i explain whats wrong and what does he tell me to do "bend it" so i say "no this would make it very inaccurate". so at the moment i am trying to get my money back but am waiting to speak to the owner. the pleb i dealt with reckons they cant take it back but thats another story.. so has anyone got a gauge the same as this and if so can you tell me where to get the proper sender or do i in fact have to "bend" or "modify" the sender they gave me?
thanks alot
http://photobucket.com/albums/v684/64morris/
PostPosted: Thu Mar 24, 2005 10:27 pm
resident alien
resident alien
mine read wrong when I bought the car so I bent it and it's now close enough.
PostPosted: Thu Mar 24, 2005 10:32 pm
Have you got a Pictures of this Wrong Sender, May help
PostPosted: Thu Mar 24, 2005 11:01 pm
ok here are some pics of the sender. also some crazy diagrams to try and explain what i mean. :| karkraft have a fuel sender unit in their catalogue but they dont know if it will work with this gauge.
PostPosted: Thu Mar 24, 2005 11:10 pm
It does look like the same as Morris..
I think it is packed straight for shipping purposes :wink: and the crude Digram re-enforces it...I THINK you would bend it before the coneections I can have a look once the fule is down :?
PostPosted: Fri Mar 25, 2005 10:51 am
thatd be great thanks gafmo do you reckon you need to bend it at the resistor connections?
PostPosted: Fri Mar 25, 2005 10:53 am
:shock:
Consumer protection laws mean it has to be "Fit for purpose". Unless it's for a very early mini with the screw mounting it probably won't seal any way even if you do bend it. Later Mini tank senders use a rubber seal and a tapered locking ring. Not a good move to bend it as then they can say you damaged it and you won't be able to take it back.
RonR
Users browsing this forum: timmy201 and 79 guests
