It is currently Mon Jul 21, 2025 8:00 am
 Post subject: trailing arms
PostPosted: Tue Mar 29, 2005 10:18 am
Dewey on ausmini needs to replace a damaged trailing arm (what i call a swing arm)
anyways its the rear susspension casting that the back wheel swings off..
the question is i have a pair spare but they are niether the parts numbers listed in the publications i have
they are numbered 21A1475 and 1476.. the numbers listed for the hydrolastic trailing arm are similar in the mini spares catalog which are 21A1485 and 1489. Dewey needs
the dry type which is listed as21A393 and 392..
is there much difference between a dry and a hydro version??, and are they interchangeable?
PostPosted: Tue Mar 29, 2005 10:24 am
Jeff,
I have a good rear suspension that is dry. You can have it for nix. G
1962 Mini Speed sports sedan
PostPosted: Tue Mar 29, 2005 10:31 am
Actually on second thought yes thanks G i can still help out Dewey , and I can make good use of the rest... thats excellent cheers G champion..will send PM asap
Users browsing this forum: timmy201 and 93 guests
