It is currently Tue Jul 22, 2025 3:53 am
 Post subject: Starter motor
PostPosted: Tue Apr 05, 2005 10:36 pm
what type of starter was would i have it looks to be the original type is this a INERTIA STARTER MOTOR or a PRE ENGAGED STARTER.
Thanks
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Tue Apr 05, 2005 10:43 pm
Early type- fitted on 100% of Oz Minis is Lucas inertia type.
If you want a better one MG Heritage has pre-engaged ones to fit `our' Minis, $160 approx.
Bolts straight in. Mini Mad has one. :wink:
PostPosted: Tue Apr 05, 2005 10:44 pm
thanks doc. i needed to no so i could order my ultra light flywheel
PostPosted: Tue Apr 05, 2005 10:52 pm
I know a few guys that have installed the Gemini Starters...but no idea which one this is :?
PostPosted: Tue Apr 05, 2005 10:55 pm
Gemini is a pre-engaged, but needs the mounting holes filed a bit to fit.
All the pre-engaged ones mesh in from the front (engine side) of flywheel.
