It is currently Tue Jul 22, 2025 8:22 am
 Post subject: Bl**dy thing sucking air
PostPosted: Sun Apr 10, 2005 1:47 pm
Resident Haemorrhoid
Just when i had it running beautifully :D
it started to run a bit rough then terriblly :( :(
i investigated couldnt see any reason then whilst running sprayefd a bit of "Start ya bastard" around the manifold and she reved up :(
started looking for the air leak ( carbie was re bushed 4 weeks ago)
still nothing obvious so i pulled the thing of thinking that one of the gaskets had gone
boy did i get a nasty suprise
look what i found :o :evil: :evil:
no wonder it was sucking air :evil:
any way after sourcing a 2nd hand throttle body for $35 its up and running again :D
now i have all the mucking around getting the ratios right :(
i guess its all part of owning a Mini :lol:
cheers gadget
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Apr 10, 2005 1:49 pm
Far out!
How the hell did you crack the throttle body like that? :shock:
PostPosted: Sun Apr 10, 2005 1:50 pm
that sucks man,, but btw i love your clubby, i was going to put chromed fatties on Vivian i have some under the house, but would need to get them re-chromed, so decided agaionst it....but your car loos preety schweet!
PostPosted: Sun Apr 10, 2005 1:52 pm
Buggered if know :?
maybe it couldnt handle the G forces :wink:
worst part is i had just had the thing rebuilt :twisted:
is alloy welding good these days is it worth doing or should i just write it off to bad luck??
thanks czerial its still got a long way to go but its getting there when time and money permit and getting the two of them together at the same time
Gadget
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Apr 10, 2005 3:00 pm
dude is your new throttle body as shiny as your old one?
thats one beautiful carby
even the butterfly is polished
Inconspicuously Conspicuous
PostPosted: Sun Apr 10, 2005 3:39 pm
Holy crap......................... :shock: . Bad luck right there, hope all is well again now, and you can dial the other one in again 8)
I got nuthin......................
PostPosted: Sun Apr 10, 2005 4:31 pm
czerial wrote:
that sucks man
Thats cause it was cracked...
:lol:
I am intrigued too though. How does something like that crack..? Was it dropped?
PostPosted: Sun Apr 10, 2005 5:54 pm
No to the best of my knowledge it hasnt been dropped the only thing i can think of is that I may of been a bit over zelous tightening the thing up or it wasnt dead flat not sure.
what i can't understand is why it didnt crack straight away it was fine for 4 weeks then all of a sudden it fails :? :?
any ideas?????
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Apr 10, 2005 5:58 pm
:shock: :shock: that shouldnt happen, was it the carby place that may have done
it, other than that its just weired
PostPosted: Sun Apr 10, 2005 6:49 pm
Could it be the steady bars on the engine are a bit sad and the engine has rocked back causing the carby to hit the firewall?
PostPosted: Sun Apr 10, 2005 7:42 pm
Not hard to alloy TIG weld it, but it's only a bloody HS4... I'd just pull another off the pile in the corner... :lol:
