It is currently Tue Jul 22, 2025 8:17 am
PostPosted: Mon Apr 11, 2005 2:33 pm
HELP
My Hand break cable snapped on the left side and i have bought a new 1 is it hard to install or should i pay someone to install it ??
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Mon Apr 11, 2005 2:51 pm
I've never done one so I don't know but it doesn't look hard, hardest bit I have had experience with was getting it out of the swivel bit on top of the rear radius arms.
The track/ slotted bit is closed up so the cable can't come out stick a flat screwdriver in it and lever it appart :wink:
Roads need more corners
PostPosted: Mon Apr 11, 2005 3:07 pm
I can't do much to the car, but that job is PISS EASY!!
just undo the adjusting nut off the lever and the two bolts holding the cover on where it goes through the floor. Feed it through and just follow it along - very self explainatory. Doing only one side is even easier because you have the other side for a reference if you forget where something goes. But probably not recommended just replacing one side as they stretch over time so the pressure may be uneven between the two sides. for how little they cost just do both - good practice anyway!! :D
Bob Slattery
Users browsing this forum: Bing [Bot] and 96 guests
