Hi. Ive recently fitted up my modified clubman centre AM radio.
As you can see in the pics, it turned out quite good.
I used a heat gun to strip the whole thing back to bare metal. I then welded up some supports at the top where it was a little bit weak for my liking, and also at the back where the grille was ripped out from.
I primed it up in two coats and then finished it off with another few coats of semi-gloss black paint.
I then got some stainless steel and brushed it up then glued it where the grille was and mounted a cigarette lighter in it, which i will use for charging my phone and iPod.
Later on, i will mount some toggle switches in it for various things which functions i havent decided yet.
I still need the black vinyl that covers the back of the bulkhead, as you can see that fibrous crap is not very sightly.
Finished product
Just after i'd welded it up (tried zinc plate in the grille, looked crap)
In prime coat
With chassis mounting
All finished.
