It is currently Thu Aug 21, 2025 8:00 am
PostPosted: Sat Dec 12, 2015 5:41 pm
I have a square plate that bolts to the drive flange, with a bit of steel bar welded to it.
I put that in the vice then tighten away.
Also handy to do balljoints on the bench and torque them up properly (72 lb/ft).
Can also use on the car to torque the CV nut without standing on the brakes.
All the other`oles have served various purposes..!
PostPosted: Sat Dec 12, 2015 5:55 pm
Mine is not as flash as Docs but it works ok and only took 5 minutes to make.
PostPosted: Sat Dec 12, 2015 6:27 pm
I get them up as close I can on the bench. Not usually very far off. I check them again once the wheel is on, car is back on the ground with the wife standing on the brakes for good measure.
PostPosted: Sun Dec 13, 2015 7:02 am
Might try the Plate and Bar trick
dont have any drums laying around
1970 MK2 Cooper S
Users browsing this forum: No registered users and 203 guests
