It is currently Fri Jul 18, 2025 1:08 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 19, 2020 6:00 pm
simon k wrote:
Be interesting to see if it has straight cut gear set in it as Morbo28 suggested.
It does sound like straight cut drop gears, but you'd think the seller would mention that as a selling point. They're not cheap...
If it has a breather on the flywheel housing you could take that off and look down the hole with a horoscope, you should be able to see the primary gear teeth
The flywheel housings I have, have a couple of baffles between the breather hole and the gear set, so I doubt a boroscope will do the job.
