Yes, i did try the water-wetter, but it lasted only two days, and then a welsch plug fell out on the dyno
There goes thirty bucks of additive and another hundred in labour. Bugger. I'm a little hesitant to spend another thirty bucks right now...
I'd rather
fix the problem, rather than just 'patching' it for now. Lets face it, its not a genuine fix, just a helper.
I'm thinking of getting the blanking plate taken out of the side tank of the rad, and returning the flow of the coolant back the way it was in the alfa. This is the only thing i have changed to the core, and it used to cool our other alfas fine. (don't ask, a scary part in our lives) I'm thinking of changing the way i mount it, too. I will make the rad into its own full-width shroud, so all air that comes in the front of the car must go through the core, not just go around it. I'll also put a normal filler on it, instead of the header tank.
Might have to build in a cold-air feeder for the weber, too
I'm just glad i don't have a story like Spaceboys' to tell, as it has only cost me $120 so far. I'm still 100 infront, i guess.
I have an AutoMeter capillary gauge in the car, but as yet i can't find an adapter to suit. It has the same thread as the Mini head, but is too long. Can anyone help out there
