It is currently Fri Jul 18, 2025 7:05 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jul 28, 2004 7:47 pm
Very little difference really, between a Dellorto and a Weber of the same type. On the road a Dellorto is as good as a Weber, on the track I'm not sure. If jetted right I think probably there's SFA difference.
Main operational difference is a Weber has a piston type accelerator pump (like yer HQ Holden) while Dellorto uses a diaphragm. They both work.... :wink:
Dellorto stopped making carbs for cars a while back, but you can still but Weber new if U got $$$.
PostPosted: Wed Jul 28, 2004 7:56 pm
just out of interest.....are there any holley carbies that would work on an A-series?
PostPosted: Wed Jul 28, 2004 7:59 pm
I've seen a 28/36 DCD compound Weber fitted to an A series but never a Holley. The Weber DCOEs and Dellortos we're talking about here are nothing like a Holley... :wink:
PostPosted: Wed Jul 28, 2004 8:06 pm
yeah i knew holleys are quite different, just i was looking at a street machine mag (almost everything has a v8 with a holley) and i wondered if any would work on a mini
what is the difference between a DCOEwebber/DHLA delorto/SU to a holley?
PostPosted: Wed Jul 28, 2004 8:24 pm
This will be brief- I haven't got all night... :lol:
There's a lot more to it than what I've written below. Buy a book on carburation if you want to learn lots..
Weber DCOE, Dellorto DHLA, Solex PHH are 2 barrel (aka `choke') sidedraft carbs. Fixed size jets with several fuel circuits per barrel.. Basically 2 identical carbs in one body. Both throttles open together. Normally used one barrel to each inlet port.
SU is a sidedraft but can be used up to 30* angle. Single barrel, constant vacuum carb. Uses a single jet and a needle to vary fuel flow. Used 1 per port (all Coopers) or 1 to feed both ports (stock Mini).
Holleys vary in design, are all down drafts, but a 4 barrel Holley used on V8s has 2 primary and 2 secondary barrels. The small primary barrels work together up to around 1/2 throttle then it opens up the biggies either by vacuum or mechanically. They do work OK on V8s or Chrysler 4.3L Hemis.. but are way too big for yer Mini.. :lol:
PostPosted: Wed Jul 28, 2004 8:31 pm
thanx doc....yeah i once read up on them a bit.... but that was ages ago.
what you said does sound very familiar though.....cheers
-jimmy
PostPosted: Thu Jul 29, 2004 2:45 am
Doc I was told that the post polution Webers are a pain to tune right and was advise to get only the pre polution (ie 45DCOE13). What does Hamil or your experience say about the post polution Dellortos and what 45DHLA model is the right one?
PostPosted: Thu Jul 29, 2004 7:38 am
Mike,
There are some emission 40DCOE Webers where the idle bypass circuitry is fixed and cannot be adjusted. These are a PITA according to Hammill.
All the 40DHLA Dellortos I've seen (off Alfa 2000s) have screws so you can shut this feature off. But Hammill says it is handy to have this adjustment as you can better equalize idle mixtures.
Main other difference compared to early (desirable) ones is they have more bleed holes in the progression circuit. So progression from idle is a bit leaner.
Hammill does say on p9- "No competition engine should ever be equipped with an emission type Dellorto or Weber 40mm carburettor"
Take out the cover screw for the progression holes- if it has 2x or 3x 1.0mm holes in there it is the early type (GOOD!) if 5 larger (2.0mm) holes it's an emission carb. Not as good...
This doesn't mean you can't use them though. Cheap to buy and try... 8)
My Dellorto is just marked DHLA 45 and has no bypass circuits. Dunno what it's off.. :wink:
<re-edit> , 'coz I f**ked up the numbers..
Dellorto DHLA 40 `C' and `E' are pre-emission, but the F, G, H, L & N are emission ones according to Hammill. Best one is DHLA 40 (no suffix).
With Webers, he says 40DCOE 11 and DCOE 2 are the ones to have.
Last edited by drmini in aust on Fri Jul 30, 2004 7:51 am, edited 2 times in total.
PostPosted: Thu Jul 29, 2004 9:37 am
thommo09 wrote:
hey i dont mean to hijack this thread or anything......but does anyone know what carbs were used on a fiat 124? they use a twin carb set up but i cant tell if they're webbers or delortos or what size they are
can anyone tell me how to tell the difference?
these are dellortos with plastic jet covers on the top of the carb
this is the weber with brass/ steel jet covers on top of the carb .
and this is the solex side draught carb with rorary choke on top.
lookin for another clubby
PostPosted: Thu Jul 29, 2004 12:14 pm
yeah they're all pretty similar hey?!?! :shock:
PostPosted: Thu Jul 29, 2004 12:25 pm
if you are going to a wreckers take the pix with you. chances are you will be looking at either a dellorto or solex as not many webers were fitted as standard. if you look closely at each carb it will say dellorto, solex or weber on it ;)
PostPosted: Fri Jul 30, 2004 6:12 am
As far as I could gather the Dellortos with yellow plastic are the emissions ones and are not as good.
PostPosted: Fri Jul 30, 2004 7:16 am
All Dellortos have yellow plastic that I've seen. Even my `good' non-emission 45... :wink:
<EDIT> OOPS!... Just took mine off and it's BLACK so yeah, maybe you're right.. :oops:
Last edited by drmini in aust on Sun Aug 01, 2004 11:52 am, edited 1 time in total.
PostPosted: Fri Jul 30, 2004 10:51 am
mine isnt ;) and it hasnt been painted either
Image how do i tell if its the pollution carb kev ?
PostPosted: Fri Jul 30, 2004 10:54 am
Any numbers on yours, apart from `Dellorto 45DHLA'? 8)
