TimB wrote:
I still haven't checked for vacuum leak, the car is running beautifully!
I kept turning the mixture screw bit by bit towards lean until the car ran well.
This could be over compensating for a vacuum leak but I didn't fancy
having water sucked into the engine.
A neighbour said you can check the vacuum advance mech by sucking on the tube, apparently there's a diaphram inside which can split, can anybody elaborate?
having water sucked into your engine won't do much to it. If you use the wd40 etc trick then this doesn't happen anyway.
yes you can check that your vacumn advance is working by sucking on the tube. Take the dissy cap off suck on the tube you should be able to see the plate that the points are on moving this means you vacumn advance is working. If it is not moving then the diaphram probably has a hole in it. The diaphram is in the circular can type thing attached to your dizzy this is if you distrubutor has vacumn advance not all do and I don't think this would be likely to be causing your problems (alot of people don't connect the vacumn advance even if thier distrubutor has it.)
Alternatively with the engine running suck on the tube the engine should change revs mostly the revs will rise if I remember correctly.
