It is currently Mon Jul 21, 2025 6:02 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 16, 2005 6:47 pm
I used to get tolulene from Ampol before Caltex took them over. They gave me a data sheet with how much to add to make what octane. I think it was about 500ml to a jerrycan but I am not sure.
I still have about 15 litres.... :?
PostPosted: Fri Dec 16, 2005 7:00 pm
I poured about 2 litres in this morning, and did about 100 Klm today....
Definitely seemed to smooth everything out, and the Detonation cieling was much higher (well, yesterday it was about 7Psi, today it was about 13Psi)
It was still pinging but I'm putting that down to the 33' heat we had today !
Radiator temps got to about 98' but it dropped rea;;y quickly.....
Sunday (Tomorrow I'm at the Wiggles!) I'll hook up the water injection and see what difference it makes... maybe add some methanol to the water mix.......
J
PostPosted: Fri Dec 16, 2005 7:15 pm
Reading from Fast 4's & Rotaries July 92
Adding 20% Toluene to 97 Octane leaded fuel gives 102.4.
In the past ive used 20-25% Toluene (Methyl Benzine) without a problem with 96 octane fuel.
Diecast
PostPosted: Fri Dec 16, 2005 7:19 pm
So i could have gone a fair amount more.....
You could smell it though.... the exhaust had a much sweeter smell, VERY obvious if you are sniffing for it...... just a thought....
I'll add another litre in the morning and see if there is More improvment....
then after this tank, its back to 98 for me ....
J
PostPosted: Fri Dec 16, 2005 7:47 pm
I gave you the calulations on how to work it out and how safe you can take it to.
add a few more you can always water it down later.
Whats the worst that can happen?
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Sat Dec 17, 2005 1:45 am
You disolve your fuel pump diamphram :!:
PostPosted: Sat Dec 17, 2005 5:59 am
but thats su pumps for you. I have seen cars go up in flames with the old type SU pumps mounted under the fuel tank.
PostPosted: Sat Dec 17, 2005 12:34 pm
you should be able to get it from your local fibreglass wholesaler - it is great for cleaning up vinylester and epoxy resins.
don't put too much in because it tends to make the fuel form larger droplets and it takes more energy to turn it into vapour when used with carbies. whilst this means the inlet will run cooler, with weber carbs and siamese ports you are only making the fuel distribution problems worse
engines designed to run on it can use up to 95% methyl benzine (toluene) like top fuel drag cars, but your average engine just can't use that much. 10% is safe and reasonable, but be aware that some 98 octane fuels already have a high toluene content.
PostPosted: Sat Dec 17, 2005 12:36 pm
oh and kazjim don't sniff it too much, all benzine ring based hydrocarbons are known carcigonens
PostPosted: Sat Dec 17, 2005 5:29 pm
in regards to BP ultimate, i ahve found that mobil 8000 (Mobils version of 98oct) runs very well, i ahve been using that lately as i find vortex just doesn't cut the mustard, and optimax is.....not as good either. but i think maybe 8000 is a bit better that ultimate????
man its been so long since i had a tank of ultimate...
78 Leyland Mini - Prince
PostPosted: Mon Jan 16, 2006 1:36 pm
Have you tried Optimax Etreme. At 100 octane minimum it sounds a bit better than putting paint thinners in your tank.
www.100octane.com.au
Users browsing this forum: JM1275 and 112 guests
