Gus wrote:
about half a pint every 200-300miles.. is that a lot?
A friend of mine bought a NEW Morris 1100 back then, it used a pint in 400 miles during running in. BMC said that was not excessive.
I reconditioned my son's Clubby 1098 motor as few years ago, using NOS BMC boxed pistons- and it then used NO oil to speak of, it's done around 5000 miles now (but body presently being refurbished).
2 things matter on these motors to reduce oil consumption, IMO-
1. decent valve guides, valves and seals (use 1275 metro ones)- replace valves & guides if worn.
2. Piston fit- if clearance is excessive (bores honed too big) it WILL use oil.
Clearance at bottom of skirt should be only .0006" -.0012" according to the manual.
