It is currently Sat Jul 19, 2025 8:20 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 05, 2004 10:46 pm
Normal oil pressure (hot & revving) on most Minis is around 60psi, Cooper 70psi. I'd say on an old motor 50 is OK, if it gets down to 40 the bearings or pump are on the way out.
Idle pressure- anything over 20psi is OK. Depends what grade oil and how hot it is... :wink:
Autos (even old ones) should be around 60-70psi hot- they have a humungous pump, compared to all others.. :P
Doc, oil IS the best mechanic. I cannot understand how mfrs can recommend 10,000 km intervals with modern engines (synthetic ...maybe).
However, engine reconditioners sometimes recommend 500-1000 kays with a lighter "flushing oil" AFAIR.
Whats your take on this one??? :wink: :)
PostPosted: Mon Sep 06, 2004 6:59 am
I do change the Laser's oil at 10K intervals, but hey, it's still got a little colour in it. And it doesn't get thrashed into little bits by the gearbox..
On rebuilt motors yeah, dump the oil (and filter) after 500 km or so. And just use cheapo oil up to then, even supermarket 20w/50 is OK.
Valvoline do a running in oil- it's OK for this too.
Don't use oil with additives for the first 1000 miles at least, you want things to bed in properly....
20W/50 is the best all round grade but use well known brands.
As for oil additives- Nulon, Bardahl, STP, Wynns, Molybond etc, no I don't believe in them- not for Mini boxes anyway.
If motor is that worn out it needs them, pull it down and fix it! :lol:
PostPosted: Mon Sep 06, 2004 10:17 am
Way back in the 70's when I had my 1st Mini I had an old mechanic tell me to lubricate with graphite grease and put a dolop in the oil filler - it melted and mixed with the oil. Don't know if it ever did any good - made the oil black but I did it religously every 1000 miles and even on the Land Cruiser I had for 24 years without problems.
 Post subject: FLUSHING CAN BE GOOD
PostPosted: Mon Sep 06, 2004 12:37 pm
On the other hand guys, I had this 244 my swedish blond vovlo. anyway i got it as a run around once i sold my CLUBMN if you remember. anyway i bought this car from a dude who has never maintained it in his life except for toping oil up every week due to an oil leek...."THANK GO IT HAD AN OIL LEEK" . Nor did he drive it much anyway. ok when i looked it over i looked in the rocker cover by removing the oil filler cap, and found that the head, cam etc. was all crusty looking, like it has not seen oil for years. Ok i picked the car up for $100 so it was at a price i could afford to get a new engine if needbee. I put a little oil in the rocker cover so i wasent doing it more damage, and drove it home.
On the way home i got 5 ltrs of deisal, and 2 new oil filters, i flush the engine using the deasal fuel running it for aprox 15 min, i did this twice over then replaced new oils in it.
The deasal flushed out the engine cleaning the blocked up oilpump and gallarys.
Great news and oil presure again, it ran sweet for the two terrable weeks i had it, and hated it.
Now i have a sprite that realy is no better in the engine department!!!!!
PostPosted: Mon Sep 06, 2004 2:33 pm
While we're on the subject, I need to do my first filter and oil change soon, which filter should I get? Can I just go down to Autobarn and pick one up? I'm not sure they'll have a Morris Mini label on the "Suits the following cars" list.
PostPosted: Mon Sep 06, 2004 3:49 pm
when warmed up and revving my oil pressure gets up close to 80 psi
and hovers around 3o odd on idle?
does the high 80 meen i have troubles?
cheers steve
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Mon Sep 06, 2004 5:28 pm
Redfive, i use Penrite HPR30 and it's doing good...
PostPosted: Mon Sep 06, 2004 7:07 pm
cheers steve
80psi is no problem, in my opinion. The poor old Mini crank only has 3 main bearings, and the middle one has to feed 2 conrod bearings....
OTOH, most modern motors have 5 and can get away with much less pressure.
If you take the hex cap off the relief valve, I bet either the spring has been packed with washers, or someone has fitted a ball instead of the stock relief valve (good mod) but forgot to shorten the spring... :wink:
PostPosted: Mon Sep 06, 2004 7:11 pm
Redfive, first you need to know what sort of oil filter you have. Earlier models had a cartridge type (not much experience with them but I haven't heard much good about them). Later motors have a 'normal' spin-on type filter. You will likely find a suitable filter for the spin-on type at Autobahn/Super Cheap etc, but possibly not the cartridge type. You'll need to have a look at your engine though as quite often people fit the later type spin-on filter, since it is easier to change (highly recommended that's what I did).
Anto.
PostPosted: Mon Sep 06, 2004 8:43 pm
Anto.
About the only mod you need to make for the spin on filter housing is to grind a small section of the forward frame away for it to clear the filter.
The ONLY advantage I have ever found for cartridge filters is the fact you can see the amount of crap that accumulates on it, when ya remove it. But they dont work anywhere near as well.
PostPosted: Mon Sep 06, 2004 8:52 pm
?? I didn't grind anything when I fitted mine. I simply unbolted the old filter header and bolted the new one on. Had to change the studs over since the spin-on type has smaller ones, but that was it.
PhildoD wrote:
Anto.
Also, they do have more area than the piddly element in a spin-on one.
But.. they are dirty bastards to clean, and many people get the bits inside out of order so they don't work properly.
Correct method is put bolt up throung can and fit spring, then flat washer, then seal washer, then plate, then cartridge. You would not believe how many times I've found the cartridge sitting in the bottom, with oil going over the top... :x
<edit> VW Golf spin-on filters fit, they are a lot longer with a bigger element inside. Watch out on a remote change box it that doesn't foul the reverse light switch on front of gearbox.. :wink:
PostPosted: Tue Sep 07, 2004 5:41 pm
what part number is the spin on filter that the aussie cars take,
my weirdo little south african motor takes a Z93 spin on straight on to the block.
so higher oil pressure doesn't mean anything sinister, that is a releif.
Cheers Steve.
PostPosted: Tue Sep 07, 2004 7:33 pm
Coopers (UK) filter is a Z25/2
Delphi (UK) filter is a FX0004
