It is currently Sat Jul 19, 2025 1:08 pm
PostPosted: Tue Sep 14, 2004 3:17 am
And most of the twin su setups you'd find on any British car in the 50's were like that.
PostPosted: Tue Sep 14, 2004 9:43 am
So I've learnt something :oops: Also learnt that I can clean up and put together another set or two of twins out of the bits I've collected and probably get $100+ a set :wink:
PostPosted: Tue Sep 14, 2004 12:48 pm
I've got a set like that on a Peter Manton manifold. I don't see why they would work any better or worse than a mirror image pair??
You can get around the choke issue by using the cable from a late 998 Clubman (76 on?). They have two cables joined into one handle for some strange reason. I guess one cable went to the carby and the other to something on the emissions crap. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Sep 14, 2004 1:26 pm
there are a few reasons they went left and right hand bowls - particularly for minis, but most SU setups after the 50's were left and right-hand....
1/ it looks better - have a look at that set, they look silly
1.5/ they can charge more for them
2/ easier to tune and balance - you can get your hand down between them, and there is a specific method of setting up twins properly where you set the clearance from the boomerang shaped thingy on the throttle linkage to the choke linkage - the choke linkage aint there
3/ twins were only sold on the performance minis - the ones that were supposed to go racing. With 2 left hand bowls, what happens when you go around a hard left hand corner? both carbs lean out, killing your chance of hard acceleration out of the corner, with a left and right hand, one leans out, the other richens up - compensating, therefore you can still go fast :D
there are other reasons, but I forget... the 3rd is the one you get from books
