It is currently Sat Jul 19, 2025 7:32 pm
PostPosted: Mon Jul 03, 2006 4:42 pm
can't argue with that, it's pretty good value!
 Post subject: Roof Lining
PostPosted: Mon Jul 03, 2006 7:01 pm
Here is some pic's.The crease's will come out when it is fitted so they told me.
Steve
:lol:
PostPosted: Mon Jul 03, 2006 7:30 pm
ill probably get the trimmer to just do mine..looks difficult :?
PostPosted: Wed Oct 18, 2006 1:12 pm
anyone got one of these fitted?
PostPosted: Wed Oct 18, 2006 3:10 pm
oh just read what i posted ages ago... i ended up fitting it myself and it was surprisingly easy!!
PostPosted: Wed Oct 18, 2006 5:30 pm
I have made and installed my own van headlining. Not a very difficult job.
PostPosted: Fri Oct 20, 2006 7:15 am
so how is the end result and quality? do you mind putting up some pictures?
PostPosted: Fri Oct 20, 2006 8:08 am
well i just took out the one out of my old mini, so it does have a bit of the yellow staining from the original glue - but its really not that bad. .. i can put up some pics when i get a chance
PostPosted: Fri Oct 20, 2006 8:52 am
From my website (www.justanothermini.com). Different headlining, but the installation would be the same.....
The roof lining is black velour. I sourced this from a wreck, for a measly $40. It is 'as new'. Fitting was a little tricky, but made easier by the stretchiness of the velour. I basically glued and fitted the rear, then stretched and glued the front. Always start in the middle of the window opening, and work outwards on either side. I whacked some old door seals over the roof lining edges, to hold till the glue dried. This was my own idea, and a bloody good one!
After doing the rear and front, do the rear side windows, then the door openings. Cut and glue around the pillars to suit.
One point to note......remember to poke the wires for the interior light through the lining, before you glue it down..... ;-)
Now I would say that a nice black velour head lining is much nicer than a stained, yellowed original one
