Dylan's Clubby wrote:
ahhhhh ok well i shall ahve a look at the fuel filter tomorrow.
also i'll do plugs and points while i'm there!
Don't touch the electrics until you know for sure that the fuel filter is the problem.
If you fiddle with fuel and electrics and the car won't start you will not know what to fix.
Cure one problem before you bring more problems into the situation.
A quick test to see if the filter is the problem. Remove the filter and drive up the road. If it runs Ok you know it is the filter. If it still runs crap you know it isn't the filter.
