Here are mine... i modified a Recaro seat rail that was originally designed to suit a Mazda Astina.
I cut all the tab and mounting points off with an angle grinder.
For the front:
Bought some steel plate... cut two lengths.
Bent it in my vice at home with my muscles and a hammer.
Marked and drilled holes to suit the standard mounting points.
Got a mate to MIG the brackets to the Recaro rail.
For the back:
I bought some 95mm long lengths of steel angle and two square pieces of 5mm thick steel plate.
Got the same mate to weld them to each other then to the Recaro rails.
Drilled a hole in each and then matching holes in the floor.
4 standard bolts for the front... 2 new bolts for the rear plus some 100mm long plates under the floor (because the floor metal is quite thin).
Forgot to add... the material cost me $24 all up. The rest was my time and my mate's time. If he wasn't my mate i'm sure he'd have done it for $50 or less. He's a mechanic. Just about any mechanic can wield a MIG welder. This isn't exactly a complicated job so it'd be hard for them to
MOD EDIT up.
