BohoMini wrote:
How does one flush the radiator? Whats this about reverse flushing?
Many ways with varied results . You can go to an auto parts supply place and get a bottle of radiator flush , drain the radiator when it's cold and follow the bottles directions (clean water and the bottles contents , run for however long and drain when cool then fill with whatever you normally use , coolant , water and rust inhibiter etc ) . You can take it to a radiator place who often have stronger radiator cleaners to put through but may just charge more to put a normal bottle of radiator cleaner through . You can take the car to them and get them to remove the top and bottom hoses and do a full flush which entails the reverse flush you mentioned . Basically they fill the radiator with water or whatever and hook an air hose to the bottom radiator hose and blast the air and water out the top hose , this is the reverse of the way the water circulates so will clear more crud out of it thanpushing water through from the top . You can also get the radiator place to remove the radiator and take off the top and bottom tanks and rod clean the core , they push special rods through the tubes of the radiator core and clean the crud off that way . This is reasonably expensive though but if the radiator is getting choked up with sludge then it's cheaper than replacing the core .
You can do a reverse flush yourself fairly easily if you have a compressor . Take the bottom hose off the water pump and if the hose has the heater fitting halfway up just block the end of the hose with something . If it doesn't have the heater fitting then block the end with the airgun of the compressor inside . Take the top hose off and angle it towards something to take the water away from your engine as the water will come out with a bit of force and coat everything with rust stains . Fill the radiator with water and give short sharp blasts of compressed air (if you have the heater fitting on the hose remove the heater hose and put the airgun's end in the heater hose fitting) and stand clear of the rusty scaley water that will blast out . refill and do it again a few times .
You can do similar to the block but you MUST remove the thermostat first or it will severely slow any water being blasted out .
