It is currently Thu Aug 14, 2025 5:07 am
 Post subject: Re: timing chain
PostPosted: Thu Feb 01, 2007 8:13 pm
and it IS a vernier setup/quote]
No his was NOT a vernier setup. I told him where to buy it and I helped put the thing together.
64cooper wrote:
Just replacing the simplex chain will not necessarily cure the noise as the timing chain tensioner rings can also be a problem as well as worn sprockets. If it is to be replaced, go with a duplex straight off.
Not all of them came with a tensioner or still have the tensioner. Agreed, if the sprockets are worn, ebay the $10 chain and buy a duplex kit.
PostPosted: Thu Feb 01, 2007 9:46 pm
Hi all, thanks for the advice. We bought a Duplex and the related bits from Paul at Mini Tech here in Adelaide. Total cost was just under $100, which included 2 new rubber grommets for the radiator bolts. He mentioned that it may already have a Duplex, which would make my job easier. If needed, Paul will counter sink and provide the bolts, as I've never counter sunk into metal. Does anyone know if a 1 & 5/16 spanner will work on removing the camshaft gear retaining nut or must if be a socket?
graham in aus wrote:
On the "Being gassed by exhaust issue" there are some wierd things that can happen with the windows open, does your exhaust tip end still under the car, i.e. not sticking out past the rear beaver panel?[...]
The gassing is worst with the windows closed. We have to drive with at least one open or there is a 'build up' of exhaust fumes that can be over powering and stinky. The exhaust tip does extend past the rear. Our mini is a 76 panelvan and it does have fairly good rear door seals but after closer inspection today we think we are going to replace them.
Thanks for all the advice so far!
Marty & Manda
PostPosted: Thu Feb 01, 2007 9:56 pm
I don't have a spare nut to check the cam socket size soz. Not gonna make a guess either in case I stuff up...
Pretty easy to do so if you want to have a go. You can get a drill bit slightly larger than the diameter of the top of the countersunk screws you would have. Us a drill to put the countersunk holes into the plate. Press lightly and go easy is the trick first time. Every now and then drop the screw into the hole and check to see if it's deep enough to make the top of the screw flush with the plate, no deeper..
Wipe the plate over to remove the remaining swarf.
Users browsing this forum: No registered users and 184 guests
