It is currently Thu Jul 31, 2025 8:22 am
PostPosted: Fri Mar 09, 2007 6:24 am
stuvz wrote:
mine usualy sits at 40 when at idle and is about 60-70ish when driving at 90
Mine's taken to sitting @ 60 PSI whether I'm at idle or at speed? Is this a problem? HPR30 was used at last change.
Pearl - 1275 MG Metro Powered '65 Mini Deluxe
PostPosted: Fri Mar 09, 2007 1:05 pm
hey i would love to just that i dont know how too im still new to this forum ..
how do i do it ?
PostPosted: Fri Mar 09, 2007 1:22 pm
I thought when driving it was supposed to drop as the oil thins as it gets hotter and therefore loosing pressure. I was made aware that higher at idle not higher whilst driving.
edit:
on another thought and extra information about my situation its drop down to 30ish after a while after the oil heats and thins
PostPosted: Fri Mar 09, 2007 4:26 pm
If the bearings are in really good condition with tight clearances the oil pressure could easily be 60 at idle. Some Mini's have the oil pressure relief valve set at 60 (my sister's Mini K did from new). When the oil is cold and thick the valve will divert excess oil back to the sump and stop it exceeding 60. When the oil warms and thins out up the pressure still stays at 60, the valve just diverts less oil. My GT used to have 60 at idle and 75 when running only because the valve was set at 75.
Penrite oil seems to maintain it viscosity really well, this could contribute to the pressure being higher than normal at idle. A good thing.
Pete
PostPosted: Fri Mar 09, 2007 4:47 pm
Low oil pressure can come from worn bearings (mains, big end, cam), worn oil pump or a sticking pressure relief valve (unfortunately rare as this is the only easy one to fix).
As long as you have some oil pressure at idle, 5-10psi, and more than 40 when running the motor won't be too bad. A max of 40psi normally means the bearings have wear and any high revs will only make it worse very quickly. Kind treatment will help the engine last.
Because Mini's share the engine oil with the gearbox you get small particles chipped off gear teeth and synchros mixing with the engine oil This goes through the oil pump before it gets to the filter and can decimate the pump if oil isn't changed regularly. The oil filter will save the breaings but if the oil filter gets clogged with gunk the oil will eventually bypass it and all the gunk goes through the bearings they will wear very quickly. Regular oil/filter changes will really extend the life of a Mini engine.
Pete
 Post subject: Re: loss of oil pressure
PostPosted: Fri Mar 09, 2007 6:37 pm
min196 wrote:
hey i got a 1970 mini innocenti it got imported from italy i was just wonder wat i could try to fix the loos of oil pressure
The Innocenti over here has different readings on the gauge,not like the Smith guage.
PostPosted: Fri Mar 09, 2007 6:48 pm
They are the same basic movements though, with different stenciling for italian drivers. They should read the same comparitively.
I think a special gauge the italians use is the "How hot am I" gauge.
 Post subject: some pics
PostPosted: Fri Mar 09, 2007 9:19 pm
hey here is the the site to see some pics i dont have any more but when i do ill put them on
http://s177.photobucket.com/albums/w237 ... 439106.pbw
 Post subject: Re: some pics
PostPosted: Fri Mar 09, 2007 9:55 pm
Hey-You got badges on the bootlid like this? And where are you located?
Thanks.
PostPosted: Sat Mar 10, 2007 12:16 am
Pete
I drop to to 30-40 after she's been running for a while especially motorway driving. is that normal for a rebuild with not much usage since the build?
PostPosted: Sat Mar 10, 2007 5:51 am
It should have more than that, unless you are talking at idle.
If that's all it has at speed and engine is fresh, maybe the relief valve is sticking.
I don't use them anymore, instead I cut 4mm off the spring and replace the valve with a 9/16" steel ball. I put a piece of 5/16" dia steel rod 40mm long inside the spring, so it doesn't bend and unseat the ball. :wink:
This mod dramatically inproves the pressure at idle- the ball seats properly, where the original valves never do.
<edit> I pack the spring if needed to give me a max of 65-70psi, hot.
PostPosted: Sat Mar 10, 2007 7:26 am
nah wasn't talking idle....I'll double check it again after a oil change and see how I go. If not I migght ave to get it looked at. Cheers for the heads up Kev.
PostPosted: Thu Mar 29, 2007 9:32 am
Been meaning to write this up since last Thursday night. I noticed a drop in pressure especially on Sunday on the cruise whether i was doing 60/80/100 oil pressure ranged between 15-40 but averaged out around 20 and dropped down to like 10ish at idle. I know the bearings are brand new(mains/big end/cam), NFI about the pump and the pressure valve is brand spanking. By what I've read or rather taken it to mean my engine running like a dog with those pressures at idle and under load.
WORRIED....:? :? :?
PostPosted: Thu Mar 29, 2007 11:20 am
i had this recently... thank goodnes... :)
PostPosted: Thu Mar 29, 2007 11:47 am
how do I check if its sticking??? or is there anything I can check myself without having to take it somewhere to be looked at?
Users browsing this forum: lomin and 76 guests
