It is currently Sat Aug 02, 2025 9:46 am
PostPosted: Sat Mar 17, 2007 5:37 pm
I've never had a problem with the pressure limiting valve, which is what yours is. Unlike those crap `FAM' valves used on the last of the Clubbies here.
Either:
1. You are standing on the pedal too hard and forcing the valve to close the circuit off- or,
2. There is crud and debris blocking the little bleed holes in the cylinders.
Take the bleed nipple right out and ensure you can poke a 1.5mm drill bit in there.
PostPosted: Sat Mar 17, 2007 5:50 pm
Anto wrote:
Anyway, I was bleeding the brakes, the old fashioned method (I have a pressure bleeder but wasn't using it) and the back brakes won't bleed properly. When I open the bleed valve a tiny bit of fluid comes out but the brake pedal barely moves... certainly won't go to the floor!
When this happens all you need to do is release the brake pedel a very small amount then it will go to the floor.
Cheers Pete
PostPosted: Sat Mar 17, 2007 6:13 pm
Hmm interesting point, we were doing the 'pump pump pump hold release bleed nipple' rather than the 'release bleed nipple and push brake to the floor' method. Perhaps tomorrow I'll attack it with the pressure bleeder, that removes the brake pedal from the equation. Although the brake pedal at the moment is nice and hard and they work quite well, it's hard to tell what's going on at the back.
PostPosted: Sat Mar 17, 2007 6:37 pm
If you still had air in the back, no way pedal would be `nice and hard'... :lol:
Really, the rears do SFA, particularly if you have S rear wheel cylinders.
Many racers ran with no working rear brakes. 8)
PostPosted: Sat Mar 17, 2007 6:53 pm
In that case then, I think I'll leave it. It stops, reasonably well at that (the front pads are cheapo rubbish and they won't wear out!!)
Users browsing this forum: Bing [Bot] and 90 guests
