>Rude< wrote:
ive got straight cut gears in mine, does that change the strength of the gears?
Helical cut gears are designed to last till the end of the warranty period.
Straight cut gears are designed to last till the end of the race.
A lot of people say that straight cut gears are stronger and that is why they use them in race cars. They are wrong! Straight cuts are weaker by design but they use less horsepower to run, that is why they use them in race cars.
When straight cut gears mesh they have one tooth in contact at a time.
Helical gears can have two or even three teeth in contact at a time.
I was just about to write the same thing .... so to expand a bit on the accurate analysis above:
Straight cut gears have a smaller gear tooth contact patch compared to helical gears and yes, they do place all the engine's torque on that single thrust face of the tooth. Helical ones by design spread the load more effectively, and are therefore stronger.
So why do we use straight cut gears ?
I'm sure to manufacturers they are simpler and therefore cheaper to produce, although more expensive for you and I to purchase because of the economies of scale.
They do use less power to drive.
And very simply, they are more readily available in the close ratios we want for competition cars. Helical close ratio sets are the ideal setup but very rare over here and quite expensive.
The close ratio sets available for Minis have a very tall first gear which makes them rather unsuitable for normal road use in metropolital areas.
Curly
'67 Mini Marcos GT
www.mm7056.wordpress.com
