smac wrote:
Hmm....the whole point about "top mount point not designed for reel belts" always seemed to make sense to me - never saw the need to question it.
However, having read the comments above I'm not so sure any more - as soon as the belt starts to 'unroll' quickly, the reel locks, and then (I now think) the force on the top mount point is diagonally down toward the mount but the handbrake, the same as if it were a static belt.
Now for the bit that may not makes sense, but I haven't had anough sleep this weekend and am just thinking out loud....
If the belt stretches, and/or the belt tightens on the reel, yes the belt will pay out through the top loop/mount and also the centre mount....but nothing in my understanding of physics (good in some areas, dodgy in others!) tells me that the force exerted on the top mount is any higher than it would be if a static belt was attached to that point instead....regardless of which point is fixed or a 'pulley', the overall work done in stopping your body moving forward will still be split between the three points. In fact my very tired opinion is that a reel belt may in fact do a better job of sharing the load between the three points....
Think of a 4WD snatch strap....you could do a dead pull all day and never move a stuck car (just burn out a clutch), but, the extra force exerted when the "snatch" "snatches" will often overcome the inertia.
