It is currently Tue Jul 29, 2025 12:11 am
PostPosted: Sat Jun 23, 2007 7:26 am
970 & 1071 S blocks are about 1/4" shorter in height than 1275 S and non S 1275 blocks, so the height difference and the bore size means its probably a small capacity S. There should be a tag with the capacity attached to the back of the block next to the casting bump where the fuel pump goes on mechanical fuel pump A series engines.
AEG163 is an S head. From what I understand these came in two versions, yellow and blue. This refers to the colour painted on the top of the head under the rocker cover. The yellow heads had a tendancy to overheat and were replaced by the blue head which used a modified casting to improve cooling.
Re the 9FC engine prefix.
9F is an engine prefix used for minicooper engines irrespective of capacity or type (S, non S etc) Exception is the UK MK3 S.
The F means twin carb engine and is used on other BMC engines as well
Don't know what the C means.
Checked my workshop manual circa 1971 and it shows 9FC as the prefix for a 970 S. It also shows 12FA as the prefix for 1275 S engines which is wrong so the C is probably wrong as well. 12FA is a prefix used for engines in cars such as MG1100s etc which used a twin carb non S 1275 engine. Looks like somebody at BMC got their numbers mixed up.
Just to add to the confusion my MK1 S gearbox has a 12FA prefix for the the gearbox number.
RonR
PostPosted: Sat Jun 23, 2007 7:36 am
According to Parnell's Original Mini Cooper book book there were only 3 variations- 9F/SA/X, 9FD/SA/X, and 9FE/SA/X. The letter X represents 10:1 C/R, while the D originally meant Positive breathing system, then became an administrative change to E when reclassified as Carburettor Crankcase Ventilation.
No mention there of a C....
Like Ron says these blocks are shorter than a 1275. I'd check the stroke- should be 61.91mm if it's a 970. A 1071 would be 68.26mm. :wink:
PostPosted: Sat Jun 23, 2007 3:21 pm
Removed the drop gears, squirted some oil around, and turned over by hand :D . Funny you should mention the stroke a quick measurement gave me around 62mm.
doc, if ya listing doesn't show the C, what the hell have I got?
If in doubt ask
PostPosted: Sat Jun 23, 2007 3:27 pm
You have a 970S, no doubt about it. :lol: 8)
C is no doubt correct as well, Parnell's book has other errors too.
Congrats, they are a rare beast here...
Users browsing this forum: Bing [Bot] and 107 guests
