It is currently Fri Jul 25, 2025 11:44 pm
How would you paint the engine?
Paint individual components then assemble? 52%  52%  [ 12 ]
Paint individual components, assemble then give another coat to finished engine? 13%  13%  [ 3 ]
Assemble the engine first then paint it? 35%  35%  [ 8 ]
Total votes : 23
PostPosted: Sat Jun 30, 2007 10:49 am
smac wrote:
After screwing around with spray cans I want to try brush next time - can't seem to find a brush engine paint though...
Edit - interesting seeing welch plugs painted...I like 'em brassy
Factory painted them- back then they were mild steel- rusted unless painted. :wink:
PostPosted: Sat Jun 30, 2007 1:41 pm
Next time I wouldn't bother painting the clutch housing. And the gearbox (although that looks good painted). As when fooling around with bleeding clutch, filling up master cylinders and the accidental spill, my clutch cover has lots of lfaked and crapped out paint. Looks good with no paint, or with paint but not bits of paint and bits without.
But, above all the best mini engine I've ever seen is painted in metallic blue (2pak) all over and looks awesome.
PostPosted: Sat Jun 30, 2007 2:28 pm
I paint the head sperately - for a reason.
Then I turn the assembled block upside down (minus things I dont want painted, dizzy etc) so that its resting on the flat surface. I then paint it with the harmonic balancer off, replace the harmonic balance and paint it. I dont worry about the little bit of over-spray that my find its way in.
Why ???? - I do it that way because it much easier to lift a gearbox upside down onto an upside down engine block than visa versa. Once the gearbox it attached and bolted down (not too tightly yet) the assembly can be turned over (or lifted down from a bench and turned over) and the assembly continued (including the cylinder head). I dont tighten the gearbox bolts (and nuts) until the clutch housing is in position and then nip them all up together and evenly so that the clutch housing, gearbox etc are all a neat fit. I also use aviation gasket goo for assembly.
Something I learnt from Doogie is that a milk crate makes an excellent assembly stand and you can sit on a mechanic stool while you are doing most of the assembly. Doogie also tells me that a car without wheels sit comfortabley for a week on a milk crate at each corner before it begins to sag.
I dont paint the gearbox because as someone said - it quickly gets chipped by road use.
PostPosted: Sat Jun 30, 2007 11:35 pm
Resident Test Pilot
Is there a brush on engine paint or is it a matter of sraying the can into a container and brushing it on ??
I would prefer to brush paint my engine also.
Users browsing this forum: No registered users and 116 guests
