Mort Subite wrote:
I'd be using genuine or NOS over a 'bike cable' simply coz its gonna be easier to fit as it was made for the job. Mini parts as so cheap.
I use the bike cables after more than a few let downs with "made for the job" cables. Think about the loads a carb butterfly spring will place on a cable, and then the loads from a mountain cyclist grabbing a hand full of brakes. i know which one will be greater, and not by a close margin either. I use a good quality name brand bike cable because i know it's stainless steel, high grade and teflon lined. More usually anyway, if you are breaking cables, it's because you aren't greasing them before you put them on the car. For the 10 dollars for a "proper" cable, I bet it will be short, and that it will fray and rust.
Also it gives you the choice of length, instead of trying to force the cable through an unatural radius around the booster, heater tap, rocker cover and into the receptacle on the carb/s. I cut it to length and re-use the brass end fittings, grease it up and then forget about it for ten years .
