It is currently Fri Jul 18, 2025 9:09 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 09, 2007 10:20 am
My local mini mechanic uses his 3/8" Air Ratchet for wheel studs.
Swears that it does them up to exactly the right torque.
I love my air ratchet :D Saves soooooo much time, & makes a cool noise!
PostPosted: Sun Sep 09, 2007 10:37 am
With rattle guns - ½" or ¾" ? I see you can get about twice the torque from a ¾" - thinking of undoing - not tightening and I already have a reducer if I wanted to use the ½" sockets in the tool kit
PostPosted: Sun Sep 09, 2007 10:48 am
I have used 3/4 drive rattle guns for erecting structural steelwork and large mechanical equipment (conveyors, kilns, etc).
Stick with a 1/2" rattle gun for use on cars. Easier to manage & fit in places.
A 3/4" drive will snap/thread most fasteners used on a car.
PostPosted: Sun Sep 09, 2007 7:12 pm
I use an air saw...
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue Sep 11, 2007 6:49 pm
i bought a gmc kit with a rattler ratchet and air chisel, has served me great :D cept on rear subframe, but it just helped me break bolts and welds faster than i would have doing em by hand lol, i swear by air tools, at work and at home. light weight would have to be the plus, and chuck a pair of earplugs in and you are sweet to go :)
I have a problem.. apparently
PostPosted: Tue Sep 11, 2007 7:05 pm
½" will do everything that you need on a Mini.
¾" guns are too heavy to use on cars. They are Ok on truck wheel nuts but too big for most use.
When I had my own truck I used a ½" gun and on big heavy stuff I would crack the nuts with a breaker bar (and a bit of pipe if needed) and once it was loose I could then use the rattle gun to run the nuts off. I used a ½" to ¾" adaptor to use the ¾" sockets.
PostPosted: Thu Sep 13, 2007 11:04 am
air chisel worked well cutting out a rusty rear beaver panel
PostPosted: Thu Sep 13, 2007 12:12 pm
Does a plasma cutter count if it uses compressed air? Cos I just got one dropped off by TNT then, and it is going to be my new best friend with the cooper shell.
PostPosted: Thu Sep 13, 2007 1:09 pm
ooohh plasma cutters are fun :D :twisted:
PostPosted: Thu Sep 13, 2007 1:58 pm
Aside from a plasma cutter what is best for cutting flat sheet for body panels - nibbler, shears or cut off wheel?
PostPosted: Thu Sep 13, 2007 2:00 pm
if hand shears id say no cos it will warp the steel, but if a big guiloteen go that ;) i reckon a cutoff wheel, although i have used a nibbler ... but you still have to grind off the dags...
