Yeah, Kev sort of has it right,,, on a twin carb set up, basically each piston/cylinder sees only the one carby anyway,,, so if you have twin 1" & 1/4 carbs then each cyl is only using one carb (1"&1/4), even tho there is a small balance pipe between the two carbs, there isn`t much "Usable" air being drawn thru it.
With A single 2" SU , each piston is drawing ait thru a 2" hole, simple as that.
it`s the single manifold that is more of a restriction than the carb, twin carbs utilise a far less restrictive manifold & also help distribute the mixture more evenly across all 4 cyls than a single manifold does.
& yes my 1510cc donk is Bored & stroked , like i`ve said (160thou over bored & approx 120thou longer stroke)
Dam good "Little" road motor
