If you read my sticky post `how to put a Pulsar dizzy in yer Mini', in the Mini Mods forum, I gave dimensions in there, see the last few pages.
There are 3 different plates used, they have different slot lengths.
I've heard a D4R80 runs better (has less centrifugal advance) but we never got em...
<edit>
here's my dimensions from that post for a D4R83-
"The D4R83 plate slots are shorter and angled more, I make both 1.5mm shorter to get 10* advance, as they have a much bigger offset angle.
For a D4R83 with the slot lengths of 8.9 and 9.3mm, I make them exactly 1.5mm shorter at 7.4 and 7.8mm.
<edit>
NOTE there is another advance plate in some of these D4R83s, it's marked +15 and 14.5. It has less of a slot angle than the one above. Slot lengths here are 9.5 and 9.8mm. Make these both 1.75mm shorter to get 10*. Lengths will then be 7.75 and 8.05mm.
Precision is needed for this work, don't attempt it if you don't have the skills."
<edit 2> for D4R85-
One of the D4R85 slots is 10.3mm and the other is 10.7, the slot is 5.0mm wide with a 2.5mm radius at outer end. I make them each exactly 2.0mm shorter at 8.3 and 8.7mm.. WELD THE OUTER END OF SLOTS ONLY.
Yours appears different. You may need to do what I did and mark out 0° and 10° marks inside the body with a protractor, lock the shaft at bottom, then see what size drill bits you need to fit in the end of the slot slot to limit the plate movenent to 10° max.
