It is currently Thu Jul 24, 2025 2:12 am
PostPosted: Thu Nov 08, 2007 9:53 pm
A hundred and twenty bucks a pair of 7.5 inch discs online is pretty hard to complain about...
Saying that, hand the discs over the counter at a repco machine shop, and you will be shocked how cheap it can be. I had a pair of WRX ventilated discs machined at a repco shop for 11 bucks a side!! It was so cheap I complained.
It's pretty simple work for the shop. It gets expensive if you want them to come and take them off however.
That was 5 years ago however, I dunno what goes on these days.
PostPosted: Thu Nov 08, 2007 9:54 pm
I paid B&R Brakes $30 each to do my S ones last year. :wink:
Or was it $30 for both... anyhow was cheap. 8)
PostPosted: Fri Nov 09, 2007 10:45 am
Anyone know what the minimum thickness the disc must be after machining ?
Crisonic
Mk1 Cooper S
Mini K Rally car
PostPosted: Fri Nov 09, 2007 10:55 am
Crisonic
haha was gonna be my next question
I have a problem.. apparently
PostPosted: Fri Nov 09, 2007 11:00 am
This space for rent
I did know, but the number escapes me at the moment... I *think* it's 8.0mm, but don't quote me on that -- someone else will confirm ;)
PostPosted: Fri Nov 09, 2007 11:24 am
My replacement set has the minimum thickness of 8.0mm marked on the outer edge.
PostPosted: Fri Nov 09, 2007 6:25 pm
why has your calliper got 2 holes because mine only has one where the rubber seal goes
PostPosted: Fri Nov 09, 2007 6:27 pm
There's 2 in one side and 1 in the other.
The extra hole on one side is for the bleeder.
:D
PostPosted: Fri Nov 09, 2007 6:28 pm
no mine only has one per side
PostPosted: Fri Nov 09, 2007 7:22 pm
these are 8.4 callipers, i think one is linked to the adjuster screw, thats wehre stuff came out when i sprayed into it
