It is currently Thu Aug 14, 2025 9:41 am
 Post subject: suspension
PostPosted: Fri Nov 30, 2007 10:23 am
i have a brand new set of 12 inch tyres ( dunlops and $50 each) but they are 165/70 series. have been told that will rub on a roundnose on front but not back ??
if i get hilos can i adjust height enough so i can use tyres without rubbing ?
 Post subject: Re: suspension
PostPosted: Fri Nov 30, 2007 10:36 am
they're likely to rub at the front, and they'll probably rub at the back too... I remember Josh (minimad) put 165/70 12"s on his clubman and had to grind away part of the radius arm at the back
they'll also screw with your gearing and the speedo read slow, and unless you've got a lot of grunt, they'll make your car sluggish
PostPosted: Fri Nov 30, 2007 1:43 pm
i got josh's wheels now, had to cut 10mm out of the section that surrounds the wheel on the gaurd ive hit a speed bump hard and it didn't scrape,
prob is now i also need to raise the car too (blueslip), im sitting about 80mm from the ground, lowest part is the sump, how quick have people swapped their car to HI-LOs
PostPosted: Fri Nov 30, 2007 1:48 pm
can you only Hi-Lo rubber cone suspension. what about hydro
I live with fear everyday. but sometimes she lets me race.
PostPosted: Fri Nov 30, 2007 1:59 pm
short answer, no
PostPosted: Fri Nov 30, 2007 3:22 pm
You've got my old wheels but with 165/60R12's...these 165/70R12's are ALOT bigger and really impractical. Mine were semi slicks and were good but if they are just normal tires it's not worth it.
My car looked like a tonka truck and was raised maybe 3inches.. Also had to grind the radius arms and they are just plain friggin huge! we're talking inches over a 13" wheel+tire combo.. 560mm is the diameter i think.
 Post subject: tyre /hilo question
PostPosted: Mon Dec 03, 2007 9:15 am
thanks for responses guys
Users browsing this forum: Bing [Bot] and 269 guests
