It is currently Sun Jul 20, 2025 2:36 am
PostPosted: Sun Jun 08, 2008 7:15 pm
A friend of mine had a 1098 Sprite motor rebuilt a few years ago by someone (who shall remain nameless), they managed to block the bypass valve to sump drain hole by trying to drill out that little brass plug below the bypass.
Anyway, long story short- it got to about 160psi before the Fram spin-on filter blew the seal out. :lol:
I've never had a problem with spin-ons, and I've used everything from cheap and cheerful to UK made Coopers and Oz Ryco.
Like M1100, I always do it up by hand then give it ~1/4 turn with a filter clamp until tight. :wink:
PostPosted: Mon Jun 09, 2008 12:19 pm
I guess you might be right.
Although, the spin-ons I use have a nice wide flat seal while the cartridge type have fiddly little thin one that you have to be very careful to get into the groove properly - and are then prone to squeezing out if the filter is done up too tight.
In my view the spinons are more foolproof.
Cheers, Ian
PostPosted: Mon Jun 09, 2008 12:31 pm
Here is a list of all the vehicles that use the Z418 filter :shock:
http://www.partsallover.com.au/details. ... cid=116353
Cheers Pete
