I am assuming here it's a 63-on 850 box, not the POS early one with Minor 1000 cone synchros instead of baulk rings... they make good landfill.
Synchro springs for the 3 synchro baulk ring box you should be able to use the same as a 4 synchro, which is p/no 22G2262.
If Kc has none, try elsewhere.
Heck they are only a spring, we do still have some springmakers in this country...
According to AC Dodd in the UK, they are rated at 4.5kg max load. Not hard to get made from a sample...
3-4 selector forks are the same for 3 synchro and 4 synchro. Kc has them listed in current catalog.
1-2 selector fork 3 synchro is p/no 22A611, if Kc has none look elsewhere.
Some people in UK just squeeze these forks in a vice and re-use them, I think it's dodgy engineering as they are cast bronze (brittle) but there ya go.
