It is currently Sat Aug 02, 2025 1:48 am
PostPosted: Wed Jul 30, 2008 9:11 pm
Die Die Die!!
the bigger bit is bout ½ a cm wide and 3/4 of a cm long, and less than a mm thick, and the smaller one is just over a mm wide and 4mm long same thickness
PostPosted: Wed Jul 30, 2008 9:14 pm
Die Die Die!!
2 S's & a clubman wrote:
They could be the Copper washers that sit under the sun gears in the diff.
Doogie
and if they stuffed up.. what would happend.. keep in mind its from a 1995 rover 1.3i... and for something as thin as it is. its pretty stiff.. but it is a small peice of metal
PostPosted: Wed Jul 30, 2008 9:16 pm
Hmmm , bit small for a thrust washer chunk , I was thinking they were bigger .
