It is currently Fri Jul 25, 2025 11:44 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu Sep 04, 2008 7:28 pm
You could use the `Kingaroy farmer' method, as Josh found on Spiro da Moke, no subby bolt loosening required at all- :!:
1. Jack up car.
2. Light oxy torch.
3. Cut one side of subby so rack can fit down and out.
4. Repeat for other side.
I AM JOKING, :lol: but yes it really was done and I still have the poor subby here as evidence.
:wink:
PostPosted: Thu Sep 04, 2008 7:34 pm
I got a rack out last night.... for those that are in-experienced... you fondle at the front, slowly reach around the back.... after a bit of experience, its quite easily done with one hand!
yeah.. mini steering rack... pain in the backside :lol:
-Cam 8)
PostPosted: Thu Sep 04, 2008 7:37 pm
gafmo(Jim) had an excellent procedure with pictures.It may be somewhere
on this site or maybe Jim still has it
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Thu Sep 04, 2008 7:38 pm
I could always cut a hole in bottom of the firewall - that would work !!! 8)
PostPosted: Thu Sep 04, 2008 7:39 pm
And dont forget to attach and tighten steering column to the rack before you fully tighten the steering rack u-bolts...this will make sure alignment is correct.....
PostPosted: Thu Sep 04, 2008 8:55 pm
This one is a Must...don't forget it, otherwise the spindle can wear and its the rack out again.
Thank Mini Me for that..I know I have it printed but now I have to see if I can find it on disk or the Net :roll: :twisted: :wink:
PostPosted: Thu Sep 04, 2008 8:59 pm
Easy rack removal? Get a Morris 1100. :mrgreen:
With the vastly superior Morris 1100 you don't need to undo the subframe, you just remove the U-bolts and rotate the rack and then slide the rack out. :D
PostPosted: Thu Sep 04, 2008 9:02 pm
Heres the one that you are looking for gafmo
gafmo wrote:
No you do not need to take the sub frame out...at all...just undo the bolts at the rear....
This has helped many people out...this will look after you :wink:
http://community.webshots.com/album/117738459JkCtax
Also try here http://www.ausmini.com/forums/viewtopic ... ck+removal
Cheers Pete
PostPosted: Thu Sep 04, 2008 9:19 pm
Bloke you Owe me one :wink: and Mini me I trust this must have help you previously 8)
Glad I printed this out at the time and also the Question on a Forum so i could follow where I was At.
Good to be orginized
PostPosted: Fri Sep 05, 2008 7:22 am
thanks that will help.
Yes gaf I do owe you one - how do you want it on my knees or from behind :P
PostPosted: Fri Sep 05, 2008 9:38 pm
Yes gaf I do owe you one - how do you want it on my knees :P
filling the fridge will be fine thanks 8)
