It is currently Thu Aug 14, 2025 12:01 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: or...
PostPosted: Sun Oct 12, 2008 5:59 pm
[quote="Morris 1100"]
or even slightly down at the front which is normal...
 Post subject: Re: or...
PostPosted: Sun Oct 12, 2008 6:01 pm
Level is normal. Down in the front means it needs adjusting.
PostPosted: Sun Oct 12, 2008 6:04 pm
I like the idea of level....
all the books give one measurement.....regardless of auto or manual
1969 Morris 1100 S Automatic
ahhhh......the interior smell of an old British car....
PostPosted: Sun Oct 12, 2008 8:57 pm
For a fat old land yacht wallowing Morris 1100 maybe..but not for a Mini :D
[just so people don't confuse their hydro's :lol: ]
PostPosted: Mon Oct 13, 2008 5:38 pm
Minis are also supposed to be level. (or nearly level)
When you lower a Mini by dropping the hydro pressure the helper springs in the rear will not have enough tension to keep the car level. So the result is a nose down attitude.
PostPosted: Mon Oct 13, 2008 7:40 pm
hmmm
Not sure if its related to the above, however when my car was pumped up the rear went up first then the front as it got to close to the right (factory) PSI. it was like the rear was being held with the springs to let the front come up that extra inch.
I was warned not to drive with the 13+" in height as the 'bags' had a tendancy (in the past) to burst at higher than 250 psi........ :?:
PostPosted: Mon Oct 13, 2008 7:43 pm
hmmm
Yep, that is how it works.
 Post subject: 300
PostPosted: Mon Oct 13, 2008 7:46 pm
hmmm
The bags should be good for 300-320 on initial pump-up...if they ain't, then they are stuffed :!:
Maurice...the Mini factory settings say about 1/2inch higher in the rear end...what you talkin 'bout Willis :?: :lol:
PostPosted: Mon Oct 13, 2008 7:49 pm
So, leading on from this...
I reckon the pressure is low in the Hydro....so
If:
- I get Mick to readjust the helper springs back to 'normal' setting; and
- Pump to normal pressure
Olli should, with a little adjusting, ride relatively level...
 Post subject: Re: 300
PostPosted: Mon Oct 13, 2008 8:00 pm
hmmm
About half an inch is nearly level. :lol:
PostPosted: Mon Oct 13, 2008 8:02 pm
I is now starting to get confused..... :?
PostPosted: Mon Oct 13, 2008 8:04 pm
It must be a Canberra thing. :mrgreen:
PostPosted: Mon Oct 13, 2008 8:11 pm
If I thought that it wasn't too low I'd drive him to Goulburn for a certain Morris 1100 expert to have a tinker..... :lol:
PostPosted: Mon Oct 13, 2008 8:12 pm
I've been trying to work out in my mind if placing a washer in the front will help the situation, I can't decide....
I figure that it will bring the front up as the rear will try to be driven down a little more to compensate, which will be counteracted by the spring..
But I think it would take a practical experiment to find out.
PostPosted: Mon Oct 13, 2008 8:13 pm
Yes is the answer...
Are you sure the rear has been 'adjusted"?
Have it pumped to the factory psi in conjunction with the factory ride height (according to the factory book Deluxe Mini is measured from hub centre to top of wheel arch - how rudementry is that!)
My line is that I prefer suspension travel to roller skate skipping, so will follow the BMC bible. If a hydro bag bursts due to age - I will just have to get a replacement - or four. However remember my car has hardly been used in comparison to other Minis ive met so material fatigue might also be a valid point for some.
Users browsing this forum: No registered users and 331 guests
