It is currently Mon Jul 14, 2025 2:21 am
PostPosted: Sat Nov 01, 2008 11:03 pm
the length of the crank would also be a factor. There are so many things to consider. Just rev it until it stops making tourqe (pulling) after that its just reving.
PostPosted: Mon Nov 03, 2008 7:31 pm
My 1275 A+ Rover engine's max bhp at the wheels is around 4200 ish (on the dyno it peaked at 120km/4200rpm) is it worth going higher than this or is that when I should start changing gears?
I normally take it up to 4500-5500rpm :?
Another question to solve an argument;
Is it better to change at max hp or at the red line for faster driving?
PostPosted: Mon Nov 03, 2008 9:17 pm
sometimes its ok to go a little higher so that once you let the clutch out in the next gear the engine revs dont drop too far down, thus keeping to in the power band.
PostPosted: Mon Nov 03, 2008 9:19 pm
Milatsmadmini
what he said ^^^^
PostPosted: Mon Nov 03, 2008 9:36 pm
It may be easier to see it :wink:
This is from a spreadsheet that I use to guesstimate what diff and gear ratios will work best. I think the power curve was copied from a 998 dyno sheet that was put up here somewhere :lol:
Basically you would want to change gears just after the lines cross over so that the rev drop during the gear change evens out. I think they say each gear change costs about a second...
PostPosted: Mon Nov 03, 2008 9:41 pm
WOW 18 1/2 HP that's crazy power :lol:
So it's better to change at max power then...good, that's what I thought.
PostPosted: Mon Nov 03, 2008 10:48 pm
No not at max power, but where the lines cross over :wink:
so first to second change is at the intersection of the blue and red line or just over 50 km/hr...
[Edit] Maybe this one shows it better;
[Edit]
